Hey fellas. First time post on here, browsing the internet I found this site and really like it. Thanks for all the info!
Anyways, I have a 2004 Dodge Dakota 4.7 4x4 with 545RFE trans, and here are my symptoms. It will move from 1st to second no problem. Then when it reaches 3500ish RPM's, it just falls into like a neutral state, but if I floor it, the transmission falls back into 2nd gear at higher rpm's. I had pulled the pan, and read somewhere that it could be an accumulator plate possibly damaged. I pulled the valve body and it all looked just fine. One of the cylinders had some minor scarring in it, but didn't seem bad at 130,xxx miles on the truck. So I then noticed the sump filter had blown out on the side. I replaced both filters, and hoped that was causing some sort of pressure loss. Put it all back together, and nothing changed. I made sure to add atf+4. I have read somewhere else that it could be the solenoid pack on the valve body; but that is a 250+ dollar shot in the dark. Does it maybe sound like that could be the problem? It throws the dreaded p0700 code as well. There was absolutely zero debris found in the pan. No shavings or sparkles. Just seems like it could be something minor before I dump a bunch of money on a new transmission. Thanks for any help.:mullet:
