I am thinking about swapping out my Dogomatic in my 99 R/T for a manual. Anyone ever done this, how bad will it be? Whats a good transmission to do the swap. Any help would be awesome.
scat_pack_dal said:yeah sorry their website isn't the best. another place to check out is keislerauto.com then click on mopar and then you'll see the dakota option. these are the guys that actually make the transmissions so they should be a bigger help.
boominkota318 said:Can I just awap it out with a 5-speed from a 5.2 dakota? Would the driveshaft length be the same? It should just bolt right up right?
razman131 said:not sure that the tranny would live long, but its would be worth a try. drive line survivability (sp) was a big part of the reasoning the 5spd wasnt offered as a option on the R/T.
boominkota318 said:What do you recommend for my auto? I have played with the TV cable a little and i have the mopar PCM, so it shifts at 5200, but by then it seems like its past its powerband and it loses power before it shifts. It just doesnt throw you back like i think it should when it shifts.
Higher stall converter and shift kit.boominkota318 said:What do you recommend for my auto?
Records no, consistancy yes. the fastest configureation will be a manual (when driven well) as it loses less power in the driveline, however while you may gain a few tenths (most I have heard of is 1.2 seconds, but that is in a SLOW car, like a high 17 sec auto, high 16 sec well driven stick).N56629 said:Shifting at higher rpms only gives the illusion of quicker shifts. The only way to get good neck jerking shifts is with a tranny kit.
I'm going to stick my neck out and say that most dragstrip records are made with autos.
The BMW's don't have a "clutchless" manual, its just that their SMG manual doesn't have a clutch pedal. Its still a 6 speed manual identical in design to the standard shift BMW's.ScatDak said:The Reason they use Automatics is for consistency not for a HP advantage. Manual Transmission are better in terms of HP Loss than a Automatic. That is the Reason your a seeing more and more cars with Clutchless Manuals IE BMW and Ferrari and such.
