1 - 5 of 5 Posts
My truck has been acting up a bit lately, it sounds like I need a new TPS based on the searches I've done on here. Just want to try to make sure. The only thing that sounds different is mine only seems to have problems when I'm going up hill.
It could be it's just less noticable when I'm driving on even land, but I really notice the RPM's jumping when going up hill.
sounds like mine did, going up hills even small grades the engine would down shift alot and rpms go up and down. my tps o ring was the problem, it was leaking air but I just changed everything o ring and tps. while your truck is sitting with engine running grab the tps plug and try to giggle it around, Mine would change rpms when I did this and I could hear the air slightly so I knew that was the problem.
1 - 5 of 5 Posts
