1 - 1 of 1 Posts
Hello,
I'm trying to replace my TPS due to RPM issue. When attempting to reassemble the new TPS doesn't fit on straight due to the 2 little plastic teeth(?) inside that the throttle blade rests against. I have to either install the TPS a little counter clockwise and then turn clockwise to line up the screw holes or vis-versa. Does anyone know which way I'm supposed to install this... a little counter clockwise, or a little clockwise. I've searched all over and haven't found an answer. Thanks! (hope my description makes sense!)
1 - 1 of 1 Posts
