I saved this from somewhere.... so here you go
TPS Modification:
(Applies to '92 -Current models)
Have you ever noticed that slight stumble right off idle when you mash the pedal to the floor? Here's an easy fix for the sluggish response of the throttle (which is related to the TPS Sensor).
Here's a chart that shows the change in the Absolute TPS% that the PCM sees
TPS Voltage Absolute TPS%
.44v ............. 7.9%
.53v .............10.1%
.685v.............12.5%
.75v .............13.7%
.82v .............15.3%
Check your TPS voltage before doing this modification as none of the factory sensors are calibrated the same. We've seen ranges from .3v-.7v...from the factory. Connect a Digital Volt Meter to the middle terminal on the TPS sensor (with the harness connected and the Key-ON/Engine-OFF). If it's close to .7v...leave it alone.
(1) Remove your TPS Sensor from the vehicle (Located on the drivers side of the throttle body - 3-Wire Connector)
(2) Put the TPS into a vice and drill the two brass inserts out of the casing with a 1/4" or 7/32" drill bit (drill from the back of the sensor...not the front). You'll need to push on the drill as it will only spin the inserts...once they're heated up enough, they'll pop right out.
(3) Clean up the holes with either the drill or (preferred) a small round file.
(4) Reinstall the TPS Sensor on the throttle body. You'll need two small washers on the screws as the holes are now bigger than the screw head. Leave it slightly loose as you're going to have to set the initial Key ON/Engine OFF Voltage before starting the engine.
(5) Reconnect the TPS sensor harness and connect a Digital Volt Meter to the middle terminal on the TPS Sensor (you can poke through the weather-proof connector).
(6) Turn the ignition key ON but do NOT start the engine.
(7) Set the initial voltage (by turning it with your fingers) on the TPS at about .7 volts. (Optimum range is from .7 - .75 volts)
(8) Tighten down the TPS screws and check the voltage one more time (yes...it can move slightly when tightening it down)
(9) Start the engine but do NOT step on the accelerator pedal...let the computer learn the new initial voltage setting.
(10) Turn the engine off and close the hood...drive away of you want...your throttle response should be much more precise now.
Here are some pictures for the various steps:
Factory TPS Sensor w/Brass Inserts
TPS Sensor in the vice (ready to drill)
Modified TPS Sensor Holes
Modified TPS Sensor reinstalled
TPS Sensor reinstalled with washers
Some have claimed that the TPS Sensor is adjustable on the actual throttle body without any modifications...this is completely false. There is no room for adjustment unless you drill the inserts out.
