What are optimal tires on a n rt rango? I want some all terrain/mud tires, I have the factory 275/60/17 on their now but I want something a lil more aggressive... its stock height but I do plan on getting either a 2in suspension lift or 3in body lift in the future so I wanna get something that will clear now but when I get a lift I want it to fit and not look small
And I plan on keeping the stock rt rims on the truck
Any thoughts? And remember I'm moving to Alabama in less than a month that's why I'm looking for at tires or mudders
Thanks in advance
You can fit 265/70R17, which is 31.5" tall. The OEM 275/60R17 are 30" tall.
You might be able to get slightly larger, but you might rub the tires at full lock depending on the manufacturer specs, as not all 31" tires or 32" tires are the height they are advertised. For instance, some 32" tires range from 31.5" to 32.5". anything bigger then 32" with moderate to heavy off-road use will lower the front differential durability.
