Been a long time since I've been on here.
Anyway, having trouble with my '00 Dakota, 4.7, auto, 2wd, 190k. First time I've ever had any running issue with this truck.
So, driving home on the interstate at about 65mph. All of a sudden it started bucking and felt like the transmission was going out. Paid attention and noticed the rpm's were dropping when doing it. Limped it home and code P1391 showed up. I know this is the intermittent loss off cam or crank sensor.
Ok, I ordered both sensors from RA, installed them, no change and still have code. Hmm, found someone that said theirs did it and the dealer replaced about 18" of wire and the plug for the cam sensor so I did the same. No change and the code lives.
I guess it could be the crank plug/wiring, or even somewhere else in the wiring, but instead of just replacing pieces at random, how do I actually trace where the problem is? I have my OEM service manual and located the pin outs for each sensor and where they go in to the ECM. I know there is a ground, a 5v power, and then the sensor wire for the cam/crank sensor.
Anyway, what type of signal should be passing out of each sensor? Is it voltage or an ohm reading I'm looking for? I read on here that another guy fixed his and it turned out to be the TPS even though I have no clue how that relates.
I'm looking for any help I can get with this as it's driving me crazy. I want a sure fire way to actually diagnose the issue and stop the BS "it might be this so replace it" crap I'm going through now. Thanks.
EDIT: Just for extra info... timing chains, adjusters, and followers all recently replaced. Throttle body and IAC valve thoroughly cleaned.
