1 - 16 of 16 Posts
I have a 2001 Durango SLT. It has the stock combo CD/Tape HU which is pretty nice. I want to add this Audiovox FM Modulator and need to take the radio out to get to the antenna plug. I see an outline around the radio and heat/AC controls that looks like it comes out, or do I have to take the whole front of the dash off??
Are there any screws to take out or just force??
And do I have to stick something in the "outline area" to pop it off??
I am hooking up this modulator to hook up my iPod to my car stereo. I currently am using a tape adapter but for one I have the wire visibly running from the tape deck to the iPod which is mounted on the floor under the dash and second it should sound better running thru the modulator.
My other dilemma is I have a Kenwood KDC-MP8017 MP3 HU , which was pulled from my Cherokee when I traded it in, that I was thinking of putting in which has a AUX input but I really don't need it because my iPod will hold like 4000 songs and the stock HU is pretty good.......what to do :confused:
Either way can someone help with my dash question???
Thanks,
Scott
kaui56 said:
i got a question...why do you have to get to your antenna for the fm modulator...dont you just tune your radio to a certain station?
You need it because the FM modulator does not broadcast a signal, it places one in the line of that antenna as far as i understand it. So in order to put the signal in the line, it must physically be in the line. Know what i mean???
Discussion Starter · #15 ·
That's an FM Transmitter (I believe), this is an FM Modulator. I had one of the transmitter's which sends the signal wirelessly to a certain station, the quality of that is pretty weak and can get "fuzzy" as you are moving. The Modulator goes between the antenna and the car stereo via the antenna cable thus giving you a stronger signal. You still have to find an "open" station to broadcast to but it supposed to work better. The Audiovox model I am using also has a switch that can basically turn the outside antenna on and off which should kill any outside broadcasting interfering with my Modulator. I am not finished with the install yet but will let you know how it goes.
Thanks,
Scott
1 - 16 of 16 Posts
