Warranty Coverage - Amsoil Warranty - Amsoil Forum
__________
Most Important: Always keep accurate service records and all purchase receipts.
__________
Warranty Coverage
Vehicle manufacturers recommend using motor oils meeting certain grades and American Petroleum Institute (API) service requirements. Whether the motor oil is petroleum based or synthetic will NOT affect warranty coverage. The manufacturer is required to cover all equipment failures it would normally cover as long as the oil meets the requirements and was not the cause of the failure.
__________
***** AMSOIL *****
AMSOIL exceeds American Petroleum Institute (API) service requirements and has never been deemed the cause of an engines failure. Even so, AMSOIL has its own limited warranty, protecting you even further. In addition, the federally mandated Magnuson-Moss Act states that a manufacturer may not require the use of a specific brand of aftermarket product unless it is provided free of charge.
* If a car dealership, service center or other business states that using AMSOIL will void your new vehicle warranty, ask for that statement in writing and send it to AMSOIL Technical Services (AMSOIl Inc., AMSOIL Bldg, Superior, WI 54880). If the business won't provide the statement in writing send AMSOIL Technical Services a letter identifying who made the statement, the name and location of the business and what the specific statement was. AMSOIL will then send a letter to the business informing them that their position is inaccurate, and, in fact violates existing law. Your name will be held in confidence. A sample of this letter can be provided upon request.
Amsoil's Limited Warranty is in effect when Amsoil Products are used in mechanically sound engines, providing, of course the oil is kept free of contaminants by changing the oil filter according to the manufacturer's recommendation or, when using an AMSOIL Super Duty Oil Filter, changing the filter based on Amsoils oil and filter change recommendations.
Additionally, if there is ever a question of whether or not a particular oil was the cause of an engine failure make sure to get a sample of the used oil in a clean bottle, typically 6 oz. minimum. The oil can then be sent to two independent testing labs for analysis (labs are located throughout the country).
__________________
A Reminder: Keep accurate service records and all purchase receipts.
An informed consumer is your best defense against being taken advantage of by a vehicle dealership or service center.
