1 - 6 of 6 Posts
Anyone use the Supreme Suspensions - Dakota Lift Kit 3" Suspension Lift kit?
I'm looking at it for a 2005 4X4 Dakota...
Thanks!
If you install a 3" leveling kit in the front, you'll be replacing front end parts on a regular basis. Don't go larger than a 2" kit up front, plenty of threads with this info.
Good info, Thanks!
Do you have a 2 inch leveling kit and a three inch bodylift on your truck?
Good info, Thanks!
Neither, just a 1.5" leveling kit up front, stock in the back. With either a 1.5 " or 2" leveling kit, the same sized tires can fit, so the extra 1/2" simply adds a little more stress on the front end, and really adds no clearance for more tire.
Nice, That looks great.
Sorry to keep bugging you but what is your wheel / tire combo's size?
265/70/17 Wrangler Duratrac, on 17" Dodge Ram wheels, which I had powder coated black. The offset on our stock wheels is 25.44 mm (Same as Ram wheels), so try and keep it close, a little lower is fine.
1 - 6 of 6 Posts
