Or you could just run the 8 rib pulley with the 6 rib belt and not worry about it??? Won't make a difference you'll just have 2 unused groves on the pulley.
Or you could just run the 8 rib pulley with the 6 rib belt and not worry about it??? Won't make a difference you'll just have 2 unused groves on the pulley.I got a eaton m112 supercharger it came with a 8 rib pulley but my pulleys are 6 rib where would i be-able to get a 6 rib pulley made with the same dimensions as the 8 rib
The belt wont jump off ?Or you could just run the 8 rib pulley with the 6 rib belt and not worry about it??? Won't make a difference you'll just have 2 unused groves on the pulley.
As long as its aligned right no. Never had one jump off yet. if it jumps off an 8 groove pulley it will most likely jump off a 6 groove as well.The belt wont jump off ?
