Folks,
My 98 ad my brother in laws 99 ... SLT (5.9L) are showing similar symptoms. I also heard the same type of engine noise on a 05 Durango Hemi.
At idle, whether in gear or not, there is a weird kinda thumping noise (ever so low) coming from the engine compartment.... you cannot hear it from the outside, nor underneath, only when sitting in the vehicle ? Does anyone have any clue ? Ever heard this or had this ? :help:
When cruising or driving around at normal speeds ... no symptom what so ever .... Should I be worried ?
My last car was a Taurus SHO. Fast as sin, but plauged with problems. The kicker was the last one. The blend door actuator (which opens/closes the AC pathway when the AC is on) became stuck and would make a sound like a 3 lb sledge hitting the firewall once every 2 seconds. When AC was engaged it would blow fully heated air out the vents. In South Carolina. In the 100 + degree summer. :cussing: I don't know if the D is set up the same way, but I shudder to think it might be.......
Folks,
Did you ever figure out where the noise was coming from or what was causing it? My 99 Durango has the same exact issue.
