I have the Flexicool on my RT and they are not steel over rubber. They are solid flexible polished stainless steel and allows the heat to escape a lot faster than the stock rubber hoses.What I see on egay is spectre and flexicool. I'm not entirely convinced these are any better then rubber, it's just rubber w/ a steel wrap that keeps heat in. Silicone would be a different story, but no one makes any molded for us. I have found a silicone by pass hose, but its for an LA motor so a little different shape and size.
good to know.I have the Flexicool on my RT and they are not steel over rubber. They are solid flexible polished stainless steel and allows the heat to escape a lot faster than the stock rubber hoses.
Only comes in one size for the radiator hoses with rubber reducing couplings and the the heater hoses are the same way. Didn't do the bypass hose.good to know.
What sizes did you use for the top and bottom? Heater hoses? stock rubber for the bypass?
I see 12" 36" and 44" lengths http://motors.shop.ebay.com/i.html?..._sticky=1&_trksid=p4506.c0.m245&_sop=15&_sc=1Only comes in one size for the radiator hoses with rubber reducing couplings and the the heater hoses are the same way. Didn't do the bypass hose.
This 48" kit will do your top and bottom hoses. http://www.summitracing.com/parts/SUM-390148/So you used the 24" 2"diameter to but the top and bottom? Heater hose must be like 1" right? My heater hose is pieced together, it'd be nice to have it in one section.
Sure is nice and shiny in there. What'd you do to the a/c lines?
This goes over the rubber part of the AC lines. http://www.summitracing.com/parts/TAY-39004/I see 12" 36" and 44" lengths http://motors.shop.ebay.com/i.html?..._sticky=1&_trksid=p4506.c0.m245&_sop=15&_sc=1
I was just showing you what I used and not saying you had to buy them a Summit. If you can find a cheaper price, Summit will price match.
Call them and ask.Will they match something not the exact brand? Some places won't.
cool, the flexacool is the same as you're describing, buy it now prices aren't bad but post us what you've got. The spectre are the wrap over rubber that we want to avoid.mine are pure stainless no rubber except for where the clamps go ill post some pics later but their earls or something like that! i know what your talking about and wont use those! i will post the auctioneer too that has alot better prices than what your seeing youll just have to watch the last minute biders
