I'm running a set with my CalTrac bars. If you put anything in the bed of your truck it will bounce off the snubbers pretty often - mine does. They also don't allow the truck to handle quite as well either since they are pretty weak and meant to just barely support the weight of the truck when empty. I run mine on the street but I am also willing to put up with the negative parts for the better 60' numbers.anybody here running the caltracs split mone leafs?i want to get them with a one inch drop to level out my r/t.pros and cons please.can u run these on the street?
Mine helped...I'm not making as much power, but since I put em on, I haven't even played with em. No spin. Zip zero nada.I'm running a set with my CalTrac bars. If you put anything in the bed of your truck it will bounce off the snubbers pretty often - mine does. They also don't allow the truck to handle quite as well either since they are pretty weak and meant to just barely support the weight of the truck when empty. I run mine on the street but I am also willing to put up with the negative parts for the better 60' numbers.
With all of that being said, I'm not even sure they helped the 60' afterall but I'm just not that motivated to swap back to my other springs to check.
