·Saw this over on the DOC Forum and though it would be of use for members over here as well...
Note: This is for the 4.7L V8.
PLUG REMOVAL
Each individual spark plug is located under each ignition coil. Each individual ignition coil must be removed to gain access to each spark plug. Refer to Ignition Coil Removal/Installation.
1. Prior to removing spark plug, spray compressed air around base of ignition coil at cylinder head. This will help prevent foreign material from entering combustion chamber.
2. Remove spark plug from cylinder head using a quality socket with a rubber or foam insert. If equipped with this engine, also check condition of coil O-ring and replace as necessary.
3. Inspect spark plug condition. Refer to Spark Plug Conditions.
PLUG CLEANING
The plugs may be cleaned using commercially available spark plug cleaning equipment. After cleaning, file the center electrode flat with a small point file or jewelers file before adjusting gap.
CAUTION: Never use a motorized wire wheel brush to clean the spark plugs. Metallic deposits will remain on the spark plug insulator and will cause plug misfire.
PLUG GAP ADJUSTMENT
Check the spark plug gap with a gap gauge tool. If the gap is not correct, adjust it by bending the ground electrode. Never attempt to adjust the gap by bending the center electrode.
PLUG INSTALLATION
CAUTION: This engine is equipped with copper core ground electrode spark plugs. They must be replaced with the same type/number spark plug as the original. If another spark plug is substituted, pre-ignition will result.
Special care should be taken when installing spark plugs into the cylinder head spark plug wells. Be sure the plugs do not drop into the plug wells as electrodes can be damaged.
Always tighten spark plugs to the specified torque. Over tightening can cause distortion resulting in a change in the spark plug gap or a cracked porcelain insulator.
1. Start the spark plug into the cylinder head by hand to avoid cross threading.
2. Tighten spark plugs to 27 Nm (20 ft. lbs.) torque .
3. Before installing coil(s), check condition of coil O-ring and replace as necessary. To aid in coil installation, apply silicone to coil O -ring.
4. Install ignition coil(s). Refer to Ignition Coil Removal/Installation.
PLUG REMOVAL
PLUG CLEANING
PLUG GAP ADJUSTMENT
PLUG INSTALLATION
