I will repeat what rock said, wrong bulb dude in the first place. You need 9007! It is much easier if you take the whole head light assembly out. Once you have removed the light twist the plastic nut to the right about a 1/4 turn. The bulb should put right out from the light. Then unhook the bulb from the wire. Install new 9007 bulb. Repeat above steps in reverse. Good Luck!
