The camshaft and crankshaft position sensors will have to be swapped from the 3.9 to the 5.2, as the OBD-II sensors will not work with the OBD-I magnets. The PCM will also not work with the engine or trans, as the transmission is hydraulic actuated unlike the 98 Jeeps trans. The only electronic control on the trans is the overdrive and torque converter lock up.
There really isn't a wiring diagram to go off of to add the extra injectors needed to run the 5.2 wit the 3.9 harness but if you have access to a factory service manual or a Haynes manual, you could go off that. Or, try to find a wrecked 5.2 Dakota from 92-95 but these trucks are now over 20 years old and they are not going to be very common in the junkyards these days.
Yes, the 5.2 will bolt up to the 3.9 trans but IDK if the motor mounts are the same. And, the 3.9 trans was the 42RH, which is not as stout as the 46RH the 5.2's came with. You can run it but if you plan on having some real fun(drag racing, road courses, etc.), then you will need to find a replacement 46RH some time down the road if you don't have the funds available right now.
