Ok here's a another game. Figure out the problem.
A :cookie: to whoever wins.
Ok...been going on for a little while. If low on fuel (3 gals) left which should still be plenty for it to run smooth the Dak starts hesitating and getting sluggish. Sometimes if it has even less but still like a gallon or two then it gets extremely sluggish to the point it barley moves. Sometimes, even with a lot fuller tank, it still hesitaes a bit here and there but generally runs a lot better. Maybe I shouldn't run in low first of all but I'm sure everyone has done it here and there. Only have done it here and there. However, that's besides the point. Even if low on fuel, it shouldn't do this.
The cat had to be replaced recently (broken up inside) so doubt that was ever it but if it was, guess it helped some. However, it's still doing it. I'm thinking clogged fuel filter? The check engine light does come on every once in a while though if driving for extended periods. That ain't often though. Far less since the Cat, EGR, and O2 was replaced. Yup, were all bad. My luck.
Needs to be smogged but wanna fix this first in case it's affecting the emissions which I am sure it is.:rant: Just wanna get some opinions before I start ripping her apart.
Thanks.
Thanks.
