1 - 20 of 23 Posts
Wheres the mud...
So i Have been searching around here, and cant really find anything about good shocks for a lifted d, any positive input would be nice, and yes i did use the search button. :banana2:
i say ask rebel13 or nick02 (i think thats his name) those are the only two that i can think of that would have good answers...i know there are more members, but i dont see them post much
Wheres the mud...
rebel seems to find every post, so i think he'll be here soon lol
What lift T/S? If so stock will work fine.
Wheres the mud...
Discussion Starter #6
my stock shock have over 120k, on them so they need to be replaced anyway, and im about to order shocks to, so im wanting to install them all at once
Wheres the mud...
Discussion Starter #7
anybody know of some good ones
You still have all stock suspension, no need to go with a lifted shock.
Bilsteins are very popular. I like mine very much.
Wheres the mud...
Discussion Starter #9
ok, so i guess a better questions, im ordering a pa body lift this week, what are good shock to go with a pa lift and t/s lift
Wheres the mud...
Discussion Starter #11
but after running the t/s lift and the body lift, wont that stretch to the max my stock shock, making it ride really rough?
Wheres the mud...
Discussion Starter #13
so with both of those mods done, just stock height shocks would work fine then...sorry and thanks for the patience, im new to trucks im a turboed car guy
CAPT. MORGAN
im still looking for longer shocks, i dont like the ride quality on stock shocks, so anyone that knows where to get some without telling me i dont need them (its more of a want) thanks for info.
like everyone is saying a simply torsion crank you dont need an extended shock on the front of my truck im running kyb mono max shocks work good offroad. I have 2.5 inch blocks in the back thats when i purchased extended shocks. For that i used rancho Rs5000 from a 2 inch suspension lift rancho used to make for our trucks. The lift might not be available but the extended shocks still are.
If you run extended shocks on these trucks, unless you have a true lift kit (cranking your t-bars does not count) you will snap the lower shock bolt often (freeway, trail, street, speed bumps, ect).
I had this problem for a long time. Even after installing the rancho 3", I would still snap the lower shock bolt once in awhile after a hard hit or jumping the truck.
I drilled out the lower a-arm to take a standard grade 8 bolt vs the one dodge had in there to make repairs easier.
AGAIN YOU DO NOT NEED LIFTED SHOCKS IF YOU CRANK YOUR T-BARS
Kevin
Wheres the mud...
Discussion Starter #20
Nither do you for a body lift
1 - 20 of 23 Posts
