I have a 2001 Durango SLT 4X4 with the 5.9L, The other day the "Service 4WD" Light came on then went off. After that the 4wd stopped working all together. I should mention that is has the shift on the fly eletric switch not a good old lever. My Question is does any one have any idea what chould be wrong? The switch LEDs do not light up at all, and the ECM is not throwing any trouble codes. I checked by cycling my key 3 times and leaving it on. I also did the easy things like check the fuses and I even replaced the switch itself, are there any relays I should look for? PLEASE help! The "Service 4wd "Light is not the problem, it is the no 4wd that concerns me. Would re setting the computer help? The dealer wants over $100 just to plug it into the computer and I just dont have extra $$ right now as you all can understand Many thanks! :help:
