1 - 5 of 5 Posts
came across a stock powerdyne supercharger for my 2000 r/t. started lookin at accessories for it and found intercoolers and what not but havent found a smaller pulley yet to run higher boost then the stock 6 psi. i heard u could run an alternator pulley on it but didnt wanna go do that and mess something up. anybody know if this is true or if i could get a link to a company that sells pullies? thnx
It's not my fault!
They are on ebay all the time. The pullies are all the same for the Powerdyne regardless of application. Also call GSM, they have an upgrade kit that allows you to use the stock tensioner to help minimize belt slippage. Also includes mandrel bent intake tubing with a boss for a bypass valve.
The higher boost levels can blow head gaskets. Felpro 1008 are a good idea, Cometics if you continue to have problems. Make sure you use a BTM controller or something similar.
you can take a stock alternator pulley and notch it and put it on your s/c...only prob it will make like 13 psi which would be too much for anything stock like...
1 - 5 of 5 Posts
