1 - 7 of 7 Posts
I'll be replacing all four shocks this weekend and wanted to know what size hardware I need beforehand? Bolts, washers, lock washers, etc. I appreciate your help!
What shocks did you go with?
What tha duece?!
I have access to new hardware, so I'd prefer to install with that.
Why waste the money? Unless you destroy the hardware during removal, you are just wasting time and money. :huh:
Shoo Shoo Retarded Flu !!
just a tip, take the top bolts, for the front shocks, off while the truck is still on the ground.
The Anti-RUB
+1 The pressure on the shock will help prevent the shaft from spinning as you try to turn the nut. A bunch of penetrating oil will also help. If the shaft still spins, vise grips on the top of the shaft do wonders. Be careful not to mar things up with the vise grips if you plan on reusing the shocks.
Good luck...
1 - 7 of 7 Posts
