I changed both filters, put in new solenoid and replaced the fluid and gasket and now I cant get the truck to crank, it is as if the truck is stuck in another gear and wont allow me to turn it over. I can move the gear shift into park and neutral but it doesn't show on the dash and shows that the truck is in low drive 1st. I tested the fluid amount and it says it is in the cold. I even ran the engine codes and it says there are no problems now when before I had a P0700 and 0750. Not sure what to do at this juncture.
Jackson
Hi,i just had a similar problem with my 03 dak 4.7 . after changing filters and fluid it would throw itself out of gear and a few other strange things I had to get truck scanned to relearn transmission to stay in gear and shift right also showed no codes hope this helps
