1 - 7 of 7 Posts
My ABS And Brake Light Came On Also The speedometer Does Not Work All Happend At Once What Could It Be?"
Ya man, your same symptoms happend to me one day comming home from work. Ran to Autozone, scanned it, said it was the Vehicle Speed Sensor. Mine was above the rear differential and not too hard to replace.
Anyways, just my experience. Keep us updated if this does end up being your problem incase noones else chimes in
Rook87 is 100% spot on. I had this problem on my '00 5-6 years ago. I was fortunate that the speedo didn't fail on me but was acting strange at speeds higher then 30mph.
It's a fairly cheap and easy repair, tip, put the truck on jack stands where the rear wheels are off the ground to give you more then enough clearance to get at the part.
Home School Valedictorian
The sensor is in the top of the differential, just a little clarification to "above" the diff. The rear brake lines are attached at the same point.
1 - 7 of 7 Posts
