whats holdin you up? is it tight at bottom or top. if its bottom, look underneath the truck right next to the drip rail. been awhile since ive done one on a dak, but fenders are typically held on by some bolts under the hood, maybe some behind headlight/grille area, open the door and check in there too. and dont 4get bout the valance. theres some that also require the inner fender to be removed from the outer. wish i could be more specific but like i said, ive only ever done one on a dak. at least a yr ago. hope this helps.
