Has anyone removed their Clutch Fan? I'd like to hear from anyone (specially people in warm climates) who has. I need to remove mine to install new Stainless Steel Radiator Hose with Billet end caps. I'm worried about overheating issues, thanks.
No problems here in NW Florida and have been without the clutch fan for about 2 years now!cilrah said:Has anyone removed their Clutch Fan? I'd like to hear from anyone (specially people in warm climates) who has. I need to remove mine to install new Stainless Steel Radiator Hose with Billet end caps. I'm worried about overheating issues, thanks.
If you haven't removed it already, it's not a difficult task. A local guy who used to own an R/T and perused this board regularly showed me how to do it easily with a MacGyvered tool he created. His setup had a simple bolt (1/4" x 3/4" if I remember correctly, like a valve cover bolt) threaded through a rectangular steel bar that was maybe 1/2" wide, 1/8" thick, and about 18" long. On the circular plate where the fan bolts up there is a handful of holes around its outer edge - feed the tool down and stick the bolt into one of these holes (not threaded, the hole is bigger- just stick it in). As you turn the fan the bar should rotate around and then bump up against one of the accessory bracket bolts, and that will hold the fan in place while you get a big wrench on the fan and twist it off (give the handle a good whack with a hammer if necessary).cilrah said:Has anyone removed their Clutch Fan? I'd like to hear from anyone (specially people in warm climates) who has. I need to remove mine to install new Stainless Steel Radiator Hose with Billet end caps. I'm worried about overheating issues, thanks.
