Ok fellaz. Kinda long post here, but please throw me a bone. I bought this hot cam for my 99 5.2 motor and I'm having pushrod length issues. It's a Crower regrind and I have H/S 1.7 non adjustble roller rockers. Yes, the cam is ground for those rr's and new lifters will be installed too. Now I could just go buy an adjustable pushrod, check the length, then buy a set of custom length pushrods. However, I'm really green when it comes to stuff like that with lifter preload and all that. So, I had this brilliant idea that involves math using the base circle diameter of the cam lobes. Tell me what you think.
The base circles of the reground cam lobes is 1.282 diameter. Now, let's say for example my stock cam base cirles are 1.382 diameter. That would be a difference of .100 in diameter, or .050 a side. I'm thinking with those numbers, I could buy a set of pushrods that are .050 longer than stock (because of the smaller base circle) and be ok with the non adjustable rr's. I also think I'll be ok with rr tip/valve tip geometry. Am I correct or full of crap?
BTW, Does anyone know the stock pushrod length? I need to know this in case my theory is correct. I believe Sam said something about them being 7.050 long. I do know H/S has a kit to retrofit my non adjustable rr's to adjustables. But I think I need to work with the pushrod length because of the rr tip/valve tip geometery. Anyway...
Your thoughts, opinions, suggestions, flames, bashings and insults are encouraged and welcomed. Thanks in advance.
