I have a 02 Durango,with 115 km . I have owned this vehicle for 4 years. At 60K, I changed the first front wheel bearing, after noticing a humming noise when turning at high speed. Since then, I have replaced both front and left wheel bearings. Left side twice, right side three times.........I have used the SKF brand of bearing assembly, in Canada these sell for around the $300 mark. The ball joints and front end seem tight,tires are newer, wheel aliignmnet good.
Has anybody had as much grief with this issue. The problems seem to arise when the weather gets wet, and these units are not a sealed unit,failed bearings feel rough when spun, the last failure totally destroyed the bearings(inner set),wheel almost fell off.
Has anybody had any similar problems, and is this brand of bearing prone to these kind of failures? Are OEM parts worth the money? Is there anything else I should look at.
N & B
N & B
