An axle is an axle. If the previously mentioned spring perches line up it will physically swap with no issues. The un seen concern would be the gear ratio. You'd want to be sure the ratio in the donar rear matches the front diff ratio from your 4x4.
I'm currently swapping a V6 8.25 drum brake axle for a V8 9.25 disc brake rear as a part of my HEMI swap.
If the springs are different you'll have to change them (you can do it yourself if you can weld and have the equipment) but most important is to make sure the ratio are the same
1 - 7 of 7 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
