1 - 6 of 6 Posts
Texas
I couldnt figure what section to put this in other then the GenIII section. Mod/admin can move this thread if needed.
I need to know how much torque a 3.55 rear end from a 4.7L v8 can take? also after re-reading the hemi-swap, did a strong enough front axle ever get found? since im looking at going to a 4x4 from 2x4/4x2. engine will be putting out close to 1000 FT. LBS of torque.
Texas
What size ring gear is it? 8.25, 8.75, 9.25?
How do you plan on getting to 1000 ft. lbs. of torque?
if i recall the build sheet correctly i think it is a 8.25, though i cant find the build sheet right now.
well i thinking of a EV conversion with possibly using this motor. would be a direct drive system so i would not need a transmission in the mix, would be directly mounted to the rearend.
Electric Drive Unit (EDU 240) - Electric Drive Motor (EDM 240)
Type: Induction Motor
Power: 240kw(322hp), at 1800 rpm, 150kw Cont.
Torque: 1300NM(960 ft-LB) up to 1800 rpm
Speed: 7,200 rpm max
Cooling: Liquid, 16L/Min, 60 deg C, Max inlet
Weight: 290Kg(640 LB)
http://www.enovasystems.com/index.cfm?section=Products&linkID=4
1 - 6 of 6 Posts
