99 Dango, 4wd, 5.2l, 84k, not limited slip 9 1/4 rear end. Just started hearing a vibration in the rear end somewhere when turning corners this weekend. I check the front end for noise while stationary and turning the wheel and nothing, also ps fluid is full. Its only when turning and I am pretty sure coming from the rear of the truck. I just talked to a guy I work with that has a Dakota, 00 or 01 I think, and he told me to jack the rear end of the truck up, and pull the passenger side tire in and out and listen for a poping and lots of play. He said if there is to take the wheel and drum off and I would see an adjuster there? Anyone know if this is the same on my Dango or any other ideas. I just changed the rear diff fluid about 3k ago and everything looked good when I was in there, however I have not checked the fluid level since I heard this noise but I will do that. Do not see any leaks anywhere either. Thanks
