1 - 12 of 12 Posts
C
Has anyone attemted to or put r/t springs on a v6. My plan was to cut 1/2" off of each end to get the drop I want and not lose anything because of the difference in spring rate between the v8 and the v6.
Very interested in anyone's opinion.
Thanks Chris
Super Modder
you have a set of rt springs already or you gonna buy them? if you got em, cut em. if youre gonna buy them, you might as well buy an aftermarket spring.
C
r/t springs
I already have them and are going to cut them. I have a 3.9l v6, how much do you think I should take off. I am going for a 2 inch drop in the front and 3 inches in the back.
thanks chris
Super Modder
i would start with half a coil, see what that will get you. then cut again if its not enough.
C
r/t springs
I've heard of coil springs settling after installation, if so how will I know what kind of drop I am going to get out of them? The guy that is helping me lower it, we talked about taking a 1/2 inch off of each end. I'll tell him the suggestion that you gave me. How do you think the ride quality will be?
Thanks chris
Super Modder
as far as settling...its used so itll settle quickly. it it settles itll probably only move 1/4 inch or so...dont forget to release the e-brake as that will drop the truck to its normal ride height. the ride is going to be a lot more bouncy...really stiff like
C
Discussion Starter #7
r/t coil springs
I have toxic shocks that are going on with the coil springs. Will that help any with the ride quality?
Thanks Chris
Super Modder
dude those are by far the shittiest shocks you can buy...itll make the ride worst than your stock shocks
C
Discussion Starter #9
r/t springs
Then what shocks should I go with, I debated going with the edelbrock shocks that were $70 a piece. Let me know.
Thanks Chris
Super Modder
ive never treid the edlebrocks but i havent heard anything bad about them. you cant go wrong with bilstiens or tokiko, im runnin koni adjustables.
C
Discussion Starter #11
r/t coil springs
what is wrong with the toxic that you don't like them and has anybody that you know tried them. What was the price on your koni and were did you get them?
thanks chris
R
Discussion Starter #12
I've got Nitro slammer shocks from sporttruckdirect.com all around on my truck with a 3/4 drop. They are only $40 a piece and ride better than stock if you ask me.
1 - 12 of 12 Posts
