1 - 20 of 20 Posts
· Premium Member
This is the procedure for enabling or disabling the "Auto Lock" option on 1997-up power lock equipped Dakotas and Durangos.
  1. Enter vehicle and close door
  2. Fasten seatbelt (prevents chiming which could interfere with procedure)
  3. Insert key, and turn ON-OFF-ON-OFF-ON-OFF-ON (do not turn the key to START)
  4. Press DRIVER's lock switch to LOCK
  5. You will hear one chime to confirm the option has been toggled
  6. Wait 30 seconds
  7. Turn key off
Repeat the procedure to re-enable.
**Note: For 2004+ Durango and 2005+ Dakota, you can also separately program the system to automatically unlock the doors when the shift lever is moved to PARK. The procedure is identical, but you press UNLOCK in step 4 to toggle this option.
· American Rebel.
Sweet finally it will work once again
· Premium Member
Discussion Starter · #4 ·
That's only a feature on 04+ Durango and 05+ Dakota unfortunately.
You are the man!!
Just did this so much better then listening to the annoying noises my locks make
· American Rebel.
Works. Feels great to have my option back on :D
· Premium Member
Discussion Starter · #10 ·
You could always replace the actuators.. Then you'd have WORKING power locks.. Now you'll never do it because that grinding noise isn't annoying the piss out of you! :D :D
:mullet:
:mullet:
I need to but 16 with no job sucks...
Im dumb. I couldn't get it to work. You go all the way forward when the indicator lights up or is that to far.
· Premium Member
Discussion Starter · #14 ·
You turn it to ON. It's the click where everything lights up but before it cranks..
The key positions are ACC(one click backwards)-LOCK-OFF-ON-START.
Also if you don't have the door closed and seatbelt on, you will be waiting too long for those chimes to finish to be able to tell if the computer is acknowledging the command.
Mine never chimed but it seemed to work i never actualy drove off just sat in the driveway in D so idk for sure yet ill watch
Didn't work on mine. Tried it numerous times
I have a 2000 Dakota. My locks will automatically lock after driving (it makes a awful noise). But neither the driver or the passenger power door locks work. I don't want to spend the money dealing with actuators. Is there a way to disable the automatic locks when your power locks don't work?
Thanks
  6. Wait 30 seconds
  7. Turn key off
How can I disable the auto lock on a 03 Durango? I have tried the on/off method twice and it still continues to lock at a certain speed
1 - 20 of 20 Posts
