1 - 6 of 6 Posts
I am going this afternoon to get a set of factory flares for my durango. I have to remove them form the other truck. are they attached with any adhesive or tape or just screwed on? Thanks in advance.
Home School Valedictorian
Both, screws around the wheel opening and adhesive tape where the flare meets the body.
Thanks man. Would you happen to know if the tape will let go if I pull on them gently or will I need a blade to cut them off?
Once you start pulling on the flares with the tape, expect it break up in several longer pieces. Nothing too bad since once they are off the tape will have to be replaced with new anyway.
1 - 6 of 6 Posts
