ok, so i tore down my sn-92 and found that it was the impeller shaft that was worn out. my question is can i just order that one part and be good to go, or do i need to order new bearings too? everything else looked perfect...the only flaw was the flat, worn out spot on the impeller shaft. bearings looked fine, but i'm wondering if i should just fork over an extra $55 and be sure. suggestions?
also, when i put it back together, what is the best procedure to clean it out some just in case some dirt or metal was in there?
