1 - 20 of 37 Posts
· 150,XXX Miles
I'm draining/filling and replacing the Transmission Pan and I'm draining/filling the Transfer Case. I'm also going to get motor oil and one of those EA Oil Filters thats rated for 25,000 Miles/1 Year (Can I trust it?). Here is my purposed shopping cart, tell me if I need anything more/less quantity wise:
6 Quarts Synthetic Universal Transmission Fluid (Transmission)
2 Quarts Synthetic Universal Transmission Fluid (Transfer Case)
6 Quarts SAE 5W-30 XL Synthetic Motor Oil (Engine)
1 AMSOIL Ea Oil Filters EAO42
1 WIX Automotive & Light Truck Transmission Filters Product Code: 58843-EA
The total price is $150.70 with the preferred customer membership, do these quantities make sense?
· 150,XXX Miles
Discussion Starter · #4 ·
the engine yes, tranny i think so, transfer case dont know
yes you can trust the EA filter...i have used them for a while.
and check here for the specifics on capacities.
http://www.amsoil.com/mygarage/vehiclelookup.aspx?url2=2002+DODGE%20TRUCKS+DURANGO+N
Ok, thank you!
I'd get two more quarts of ATF. People have seen a need for anywhere from 6-8 quarts to refill the 45RFE after a filter change. I think I put a tick over 7 in and I had the valve body down.
I'll add two more quarts of ATF, thanks!
i just love AMSOIL products,but i think you should get the 5w-30 high performance oil instead of the xl 5w-30.at $3 more a quart,it will almost double your drain interval.as far as the Ea filter,wait till you compare the filter you take off (with still some oil in it) to the Ea filter in #lbs,then let us know what you think :mullet:
· Diesel Mechanic
only way to fully switch the tranny over to full amsoil is to flush it with amsoil, then reflush again then refill with amsoil. all your doing is adding 6 qts of amsoil on top of another 6qts or atf+4...
also, change the cooler filter in the tranny while your there.
· 150,XXX Miles
Discussion Starter · #8 ·
I'll do that, but it doesn't say that I should do 7,500 mile oil changes like it does with the XL....
I know I should do a flush, but I only have the means of doing a drain and fill. Something is better than nothing....
Comes in the kit...
Are you guys talking about transmission oil pan filter? Isn't that the WIX filter I'm going to buy?
its not a should do 7500 mile change its an up to 7500 mile change...there are variables that decide how long you can go
· 99 Durango 5.9 part out
I wouldn't be so sure, mixing amsoil w/ the atf+4 that's already in there might be a waste of money at best, might destroy your tranny. I'd do some research b4 spending the money to mix amsoil w/ what's in there.
· 150,XXX Miles
Discussion Starter · #11 ·
Hmmmm.....There are Synthetic Blends on the market, wouldn't this be like a synthetic blend?
The AMSoil is fine to mix. 45RFE is not problematic anyway. Nothing like the ol' __RE/RH paperweights.
tydog - We're talking about the trans filters. Yes. There are two filters and the WIX kit includes both, as well as a pan gasket (I prefer silicone anyway).
· 150,XXX Miles
Discussion Starter · #14 ·
Phone Order
Excellent, I'll be making my order soon. Although my girlfriend made me give up online shopping for lent so does anyone have the number for our sponsor? Loop-holes are amazing! And on the AMSOIL Sponsor Sub-Forum, I see that he used to give the $10 Preferred Membership free, does he still do that?
· Blown and Squirted
We'll see how many decades the basic 45RFE architecture stays in place. :wave:
· 150,XXX Miles
Discussion Starter · #16 ·
So how many quarts should I initially put in when I refill the transmission? What happens if I go over? I don't think it's easy to take out if I do go over.
· King Snow Dog
What's the main advantage of going to Amsoil ATF since ATF+4 is already a synthetic? Just longer drain intervals?
· King Snow Dog
14.8 qts total. 6.6 initial.
2002 DODGE TRUCKS DURANGO 4.7L 8-cyl Engine Code [N]
LUBRICANTS & FLUIDS:
Engine Oil
Grade 1......API*
Signature Series 0W-30 100% Synthetic Motor Oil (SSOQT)
SAE 5W-30 Synthetic Motor Oil (ASLQT)
XL 5W-30 Synthetic Motor Oil (XLFQT)
Above 0F......10W-30
Below 100F......5W-30 [1]
Automatic Transmission,45RFE 2WD......AP4
Synthetic Universal Automatic Transmission Fluid (ATFQT)
Automatic Transmission,45RFE 4WD......AP4
Automatic Transmission,46RE......AP4
Automatic Transmission,545RFE 4WD......AP4
Automatic Transmission,545RFE 2WD......AP4
Limited Slip Differential, Rear 8.25-9.25 W/O TT......GL-5*
ALL TEMPS......75W-90 [2]
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
Differential, Front......GL-5
75W-90 Synthetic Long Life Gear Lube (FGRQT)
SEVERE GEAR 75W-110 Synthetic EP Lubricant (SVTQT)
Standard Differential, Rear 8.25-9.25 W/O TT......GL-5
Standard Differential, Rear 8.25-9.25 W/ TT......GL-5
ALL TEMPS......75W-140 [2]
SEVERE GEAR 75W-140 Synthetic EP Lubricant (SVOQT)
80W-140 Synthetic Long Life Gear Lube (FGO05)
Limited Slip Differential, Rear 8.25-9.25 W/ TT......GL-5*
Differential, Front C205F......GL-5
Transfer Case,......AP4
Fluids
Power Steering Fluid......AP4
Brake Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN)
Clutch Fluid......HB
[1] SAE 5W-30 is preferred.
[2] Trak-Lok axles require Mopar limited slip additive
limited slip additive 04318060 or equivalent
FILTERS:
Oil Filter Absolute Efficiency Oil Filter (EAO42)
Oil Filter WIX 51085 Oil Filter
Air Filter Absolute Efficiency Air Filter (EAA29)
Air Filter WIX 46077 Air Filter
Fuel Filter
Transmission Filter WIX 58846 Auto Tran Filter [1]
Transmission Filter WIX 58843 Auto Tran Filter [2]
[1] 45RFE - 2WD - Spin-on + pan filter together in one kit
[2] 45RFE - 4WD - Spin-on + pan filter together in one kit
NGK PLUGS AND WIRESETS:
VPOWER PLUG ZFR6F-11G NGK6987 [1]
WIRESET WIRESET Direct Fire Ignition [2]
[1] Plugs - SOHC
[2] No Wires Req'd
WIPER BLADES:
Blade Class Driver Passenger Rear
ExactFit T219
ExactFit T211 [1] T219
ExactFit T211 [1]
NeoForm T16210 T16210 T16160
Winter T37210 T37210
[1] With colored end tab on packaging
CHASSIS LUBRICATION:
2WD
6 Fittings, 0 Plugs..........LB
Series 2000 Synthetic Racing Grease NLGI#2 GC/LB (GRGCR)
Synthetic Heavy-Duty Grease NLGI #2 GC/LB (GHDCR)
Synthetic Multi-Purpose Grease NLGI #2 GC/LB (GLCTB)
4WD
17 Fittings, 0 Plugs..........LB
CAPACITIES:
Engine, with filter..........6.1 quarts [1]
Cooling System, Initial Fill..........17 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 45RFE 2WD Initial Fill..........5.5 quarts
Automatic Transmission, 45RFE 4WD Initial Fill..........6.6 quarts
Automatic Transmission, 46RE Initial Fill..........4.1 quarts
Automatic Transmission, 545RFE 2WD Initial Fill..........5.5 quarts
Automatic Transmission, 545RFE 4WD Initial Fill..........6.6 quarts
Automatic Transmission, Total Fill
5 speed 545RFE 4WD..........14.1 quarts
5 speed 545RFE 2WD..........14.1 quarts
4 speed 46RE..........10.1 quarts
4 speed 45RFE 4WD..........14.8 quarts
4 speed 45RFE 2WD..........14.8 quarts
Differential, C205F Front..........3.6 pints [2]
Differential, With 7.25 RingGear Rear..........3 pints [3]
Differential, With 8.25 RingGear Rear..........4.5 pints [4]
Differential, With 9.25 RingGear Rear..........4.9 pints [5]
Transfer Case, NV133, NV233..........2.6 pints
Transfer Case, NV244..........3 pints
[1] After refill check oil level.
[2] Fill to level of fill plug.
[3] Fill no higher then 3/4 inch below plug hole.
[4] Fill no higher then 1/4 inch below plug hole.
[5] Fill no higher then 5/8 inch below plug hole.
TORQUES:
Oil Drain Plug.....25 ft/lbs
Transfer Case
Fill Plug 15-25 ft/lbs
Drain Plug 15-25 ft/lbs
1 - 20 of 37 Posts
