throttle body spacer are meant to aid in total intake volume. (rinner length). the magnums already have ample intake runner length. in my opinion i think thay are a wee bit too long, and too thin. if they were designed to be about 5%-8% shorter, and just a touch wider, i think they would be better for our trucks in giving a little more torque. these spacers are also meant to help with air turbulance as it enters the intake. helps the air have a smoother radius of flow into the intake. our trucks dont need it, as if you look down the intake, there isnt an abrupt turn that the air need to make. tb spacer are great for one thing though..
a paper weight. (when it comes to our trucks that is..lol)
ive had autolights in my trucks for years, and havent had a problem with them. whats causing the pinging issue is the fact that on v8's, the back two cylinders run the hottest (also they are the last ones to see the water and by then the water is alreading hot), this created hot spots in the cylinder, any sharp spot on the piston or elsewhere, and bang (predetonation). install a one step colder plug in cylinders 7 and 8, then change your thermostat to a 180* one. bye bye pinging. did this for my ram when i had her, had a slight pinging issue, did this trick, and say goodby to the ping. btw, had alot of performance stuff on the ram too.
