well its happen to me like 3 times when i lived in houston, tx it did it to me in the summer time i took it to a dealer and thats what they said..they cleaned it and it stopped untill i got stationed at ft. campbell and i drove it there and it started again..it was running for like 8 hrs straight and it starts jerking and shooting up in the rpms and the throttle gets really sensitive..so i took it to a dealer on the way there and they reset the check engine light and they couldnt get it to act up..and then it was fine untill this past dec when we drove it to tx and it lasted a lot longer then before on road trips but it did the exact same thing so we pulled into a hotel and let it rest. the next morn the light was still on but it wasnt acting up it ran fine, that morn i took it into a dealer and they checked it and the codes that it spit out was the tcm and all injectors..reset it and happen again but on the way home i just drove it like that stopping at night for it to rest and the light was on untill i got back to tn and the light just turned off and hasnt turned on since then...any other ideas?
Do you know what the check ecgine code was, I doubt that its the PCM itself. and there are no PCM performance swaps themself, just aftermarket programmers like Superchips and SCT
Good advice here and will probably solve both your issues. When the tps starts to whack out on these it sends a weird voltage spike down the tps signal wire that you can really only catch if you are looking at it with a lab scope. When the spike occurs the pcm thinks the truck needs more fuel so it starts to fire the injectors when they don't need to be. I'm really surprised that the dealer didn't catch this as it is kind of common...at least where I live.
