1 - 8 of 8 Posts
Dakota is gone I'm not
So this is a problem I gotta fix once it warms up but here's the deal.
My drivers side window will raise and lower but the switches on both doors will not work the locks nor the passenger side window.
So I'm guessing possibly a fuse since one window still works but I'm open to other theories Thanks again!
The Anti-RUB
When you open your door, does the overhead dome light turn on? What about the instrument cluster when you turn the truck on? If they all work normally, then it's most likely a fuse. If it does not, then its the CTM which controls the head lights, dome light, instrument cluster, power door locks etc. See my thread on a similar issue with my 'D.
The Anti-RUB
The fuse is either under the hood, just behind the battery (if your facing the front of the truck) on the main fuse block or in the fuse block just behind a panel on the left side of the dash just inside the drivers door. Both are described in the owners manual. Sorry i don't know the exact one off hand. Might be a good idea to check them all while your at it.
Good luck...
Discussion Starter · #6 ·
Well I did a rough look through my fuses and all of them seem to be in working order none of them are blown I'm going to search through the forum and my manual to try and find it. I thought I read somewhere that there was a couple fuses behind the door panel. I could be wrong.
The Anti-RUB
Yes, you read it in this thread a couple posts up. Its not in the door panel though, its in the dash. You can only get to it with the drivers door wide open. Its all outlined in your owners manual.
1 - 8 of 8 Posts
