Attached to the passenger side upper control arm there is a bar that you have to take loose in order to adjust camber and caster. That bar is different than the drivers side. You can actually put it on wrong because it has a bend to it as where the drivers side is straight. I just replaced my ball joints and bushings and I think I put that bar on backwards . I have the bend going towads the block when, I think, its supposed to go towards the tire. Could somebody tell me where the bend is supposed to be going towards or if they can send me a picture then that would be awesome. Thanks
