1 - 6 of 6 Posts
The Troll Behind The Dog
So just looking for advise...Ever since I got the truck it works on and off, Doesnt seem to have any sort of trend...Just does, and doesnt...Think its the switch itself? Or another issue?
5 Door Whore #176
first thing I would do is take the switch out and clean the contacts on the connector may not be it but its worth a shot if they are loose beyond there being a problem with wiring I would point to the switch or the connection
Is it only when you bring the window down you have the problem? There is a switch for up, down, lock and unlock. If none of these others have problems, the actual copper switch may be off track or bad. If bad you will need a whole new assembly. They should firmly click in and out of place.
This is what the switch looks like, the copper parts are the bounce back switches.
If it is 2 problems, pull the panel and make sure the harness is sucured. If that still doesn't work, get another one.
1 - 6 of 6 Posts
