S
Smokin
·Guest
Hi Everyone.
Im new to the forum...my girlfriend just bought an 01 dakota quad cab with a 3.9L and 5 speed standard. It started throwing a code P0121 which is tps not communicating with the map. Then after a couple days it went away so i reset the computer and all seemed fine. Running perfect for a few days and now the light comes on again...same code P0121. It surges and loses power. VERY hard to start on a hill or under any load. BUT it is also very intermittant. It will be fine for 5 mins and then shitty again and then okay for an hour and then shitty again. Idle is fine and voltage on TPS ranges from .70-.68 at no throttle up to around 3.8...3.8 seems a little low for full throttle but ive never worked on dodges really so maybe that is normal. Im a good mechanic so any advice would be good. Thanks alot
Garrett and Crystal.
