I was having problems with this cheapo Ebay intake that I bought(SEE THIS THREAD), so I made a frankenstein type intake with parts from the old stock setup and the new kit. It solved the irregular "sucking noise" problem I was having, so that's good.
I've got a few concerns with the setup though... but before I mention those heres some pictures...
My first concern is that I was having trouble mating the new aluminum intake tube to the old airhat. Where the stock tubing ends is 3.5 inches, and the coupler is made to fit onto the inch throttle body. My solution was to use the coupler INSIDE of the stock tube to bridge the size gap, and then to make sure the aftermarket tube was pushed in far enough to give a sturdy inside to squish down with the hose clamp. It seems pretty secure, but I'm a little converned because it isn't the way it's supposed to be done. Do you think this will be safe and work out alright?
Here's a quick "x-ray" illustration of how it is put together.
Another concern I had was how to plug the hole in the tube for the IAC sensor. My solution was to just shove the air filter on a little farther to cover the hole up. I know this might reduce the air flow a little but I figured it'd be safer than trying to plug a hole with rubber or tape or something. Can anyone see any problems this might cause?
In general, after checking out the pictures how do you think it looks? Am I better off just putting the stock system back on and cutting my losses?
