J
I have just bought an 04 durango. It came with the 'raq' radio, the manual says that the sattelite radio is an option. My question is will the sattelite just plug into the radio or will i have to change radios :help:
If you didn't get the Sirius radio as an option, it's a completely different head unit plus the extra antenna. Easy way to tell is if you have it is to look on the roof just above the 3rd tail light. If you have a black triangle antenna there, you're all set. You just need to call Sirius for the activation.
P
shouldnt you have a radio id # or something my xm does but sirus is probly different.
J
Discussion Starter #4
Thanks guys for the info...I found out that I should (according to the 2nd delership I contacted) be able to plug the sattelite into the existing radio (for 300 dollars). Don't know if if I'm going to do that or use the fm modulator and get XM . Thanks again.
