1 - 8 of 8 Posts
Eatin' Ford Shittin Chevy
i have the 5.2 in my Durango. And i was plugging it in the other night so i could start it the next morning and i see this oil deposit around the spark plug shroud. so i unplug the wire and its all over it too. What does this mean? and am i going to have to fix something expensive in a quick like fashion?
all helpful answers are appreciated.
the thing is, its only one cylender its doing this in. its the second one up from the back of the motor.
6.9 6 speed
check your valve covers, breather, breather hose and the PVC valve. Shouldnt be a big issue. Have you recently changed the oil and accidently spilt some?
last time I changed the plugs in my 5.2 I had oil on the threads of one of the passenger side back 2. don't remember which. Must be a slow leak since I don't seem to lose oil noticably.
Discussion Starter #8
its the passenger side.
no, its not inside the cable. its ON it.
I changed the oil before it got really cold outside. so...early november ish im pretty sure. I might've spilt a little, but it wasnt on that side, and i drove it after it burned off once i ran it afterwards.
And i checked the oil. its at the bottom of the safe side. But i havent lost a considerable amount that i shouldnt worry too terribly much.
1 - 8 of 8 Posts
