1 - 1 of 1 Posts
1997 dodge dakota 4x4 5.2 nv3500
did some abusive off roading/mudding i’m my dakota the other day wjth some buddies.
clutch dumps, banging limiter, and just straight abuse…
the truck has 2 problems:
1. the truck jumps and shakes when you’re starting in first, and i can feel a vibration in the steering wheel, i think it might be the rear end
2. the transmission grinds really bad when the clutch pedal is pressed and also has a constant grinding ESPECIALLY when i push the clutch in. also whenever i push the clutch in i can feel the clutch/pressure plate assembly bounce back off of each other it’s kind of hard to explain. i’m guessing this is a throughout bearing
i replaced the entire clutch assembly, bearings, and hydraulics about a year ago, any thoughts?
1 - 1 of 1 Posts
