I hit a deer and busted the left head light in my 2004 Dakota. Now the the left low beam will not work, the right lo beam light works fine as do the high beams on both sides. I've taken voltage readings at the bulb sockets on each side. I get 12V or 0V depending on the dimmer switch setting on the undamaged light for both the hi and lo terminals. On the damaged light the hi terminal is 12V or 0V same as the good light. The lo terminal is always 5V regardless of the hi/lo switch setting.
Also does anyone know where is the headlight relay is on a 2004 Dakota. It's not in any of the fuse blocks.
