(DURANGO OWNER)
"NO BUS" message and "NO START" on 1999 Dodge Durango 5.2l v8 magnum
Hello guys and gals! New to this site with a very common problem.
I was driving home one day and my durangos engine just cut off-no signs of loss in power or anything that would say it was about to die- The lights and everything else that didnt have to do with the engine directly was still working. I look down at the odometer and its saying "NO BU5". So i try to start it back up but it only cranks and cranks AND CRANKS! Ive replaced the PCM,IGNITION COIL,SPARK PLUG WIRES and SPARK PLUGS but it still only cranks. Ive checked ALL the fuses/relays under the hood and there all in perfect condition. Ive ran the CLUSTER through its own test and get codes 920,921 and 999. None of the gauges work while trying to start it but they work fine through the test. The only thing that i know forsure is wrong witg my durango is that it doesnt shift into 1st or 3rd gear. Everything else works perfect. Any suggestions on what might be my problem?
