not bad looking... very different... never seen anything like it in my life. Is it all done with plexi or what? I'm not sure how plexi will hold up under higher temperatures, much less how and if that plexi will keep heat away from that COLD air you are wanting in your engine. But either way I'm gunna give you some props because I wouldn't have tryed what you did, and it looks pretty good.
where is the filter? I'm only guessing in that box to the left, but I'm not sure if I see it there. If you did use a filter, what filter did you use.
If you didn't use a filter.... ur gunna need one... thats for damn sure!
Paul
