1 - 20 of 27 Posts
Alright I've spent all morning going threw almost all of the old threads about using 285/75/16 on pretty stock dakota. I've read the back and forth comments about YES it will fit with some trimming and NO you have to have a body lift..etc. Well I found a thread of a 03 quad dakota running 285's on stock rims with just minor trimming so I know it can be done.what I'm asking for is some pics of the trimming. I just wanna see how much I gotta cut. Right now my truck is running 265/75/16 Micky Thompson MTZ on Ultra 16x8 wheels, when i put them on I had less than a half inch clearance between tire and front bumper, but then I cranked up the T/B up around 2" and got plenty of room now. I dont not take the truck off road or mudding, only see's mud when i gotta go threw it, and do not care about rubbing on lock to lock turning. I wanna put the biggest tire possible on the truck...and some pics of the type of tire to, cause I know a A/T could fit different then a M/T, I'm planning on ordering tires next week.. Thanks for the help.
I just bought some 285's. I'm gonna mount them on the stock rims tomorrow evening after work and probably do a test fit on Tuesday to see how much trimming I have to do if any. I'll try and remember to take pics if I have to trim. Oh, and my truck has the torsion bars cranked and 2 inch blocks in back (not that it matters).
Alright thanks a lot!!! Are you running a body lift? What tires did you get?
285 pics
Here are some pics of the truck with the 285s on. The first pic shows where it rubbed on the driver side I had to trim the very bottom corner of the bumper and grind down the bolt near the bottom of the bumper. As for the liner, I simply drilled a hole through it and put a zip tie though to pull it forward. I couldn't tell if it rubbed the back of the liner but I assume it will once there is some wheel travel while turning, so I'm gonna pull that back a bit. Pretty much the same has to be done on the passenger side except the previous owner already trimmed the front of the liner for some reason, so I don't have to pull that forward.
Discussion Starter #11
oh and what size was you running before? can you tell a difference in height or the feel of the truck? sorry for asking so many questions.
I was running 265/75/16 in the summer. Right now I have 31x10.5r15 snow tires on it. It definitely feels higher than the 31's. I didn't drive it much with the 285s on since I didn't get a chance to balance them last night. I only went around the block to see where the tires rubbed before I put the 31's back on.
Discussion Starter #13
was unable to run the 285's, I put on a set of 265/75/16 goodyear wrangler duratrack's and the tire hits the front bumper when you turn the wheel. And thats with a 2" T/B crank. The tires before was Mickey Thompson MTZ's in the same size and I had almost 2" of clearance between the tire and bumper. So i guess the next step is body lift.
Nice R/T rims (and truck), what size tire are you running? I just picked up some R/T rims myself and I'm looking at P265/65R17 or 265/70R17 to replace my 31/10.5R15's. The 265/65 seems a little small but I'm not sure 265/70 will fit without rubbing.
1 - 20 of 27 Posts
